Steelwolf
Someone posted about a light like this. It looks pretty good doesn't it? BUT what a bummer! You have to keep squeezing it, at high speed, for as long as you need the light! The second you let up, the glow dims and dies. Not good.
So... add this and this and 2 LEDs, some solder, a little creativity and voila!
Ok... this post lacks a little because I still can't post pictures of the finished product. I'm working on it. Item 2 was a IC bridge rectifier diode (a small square about 5mm on each side), necessary because the output from the generator part is AC, which is fine for filament globes but terrible for LEDs, and the second item which is that 1.0F 5.5V supersized electrolytic capacitor mentioned in another thread.
I set up the LEDs parallel with the capacitor, separated by a simple switch so that I can switch the LEDs on or off. I also added a Schottky diode (1N5819) on the negative terminal of the bridge rectifier between the capacitor and the rectifier because I didn't want the capacitor to discharge in to the generator coils. Was this necessary?
I also used 2 Nichia white 5600mcd LEDs in parallel. Soldered them in to an old PR bulb base. Should I have gone with only 1 LED? Would that run brighter or can the capacitor supply enough voltage and current to run both LEDs at the nominal brightness?
I will strive to put photos, test parameters and results up as soon as possible, but I would like your input on whether the Schottky diode was really necessary and thoughts if I should have stuck with only 1 LED instead of using 2.
I've charged up the capacitor. Takes about 1 minute of moderate squeezing to get it up to 5.5V (open circuit). Will post runtime results soon.
