maxhawk
I received my Millermods L1P and side by side with my standard L1P, I can't tell that it's any brighter. The hot spot is the same size, as well as the side spill. However my std L1P is a nice white, while the MM L1P seems very green. Perhaps that's why I can't tell a luminance difference.
I did measure the current at the tailcap and got 1.1A on the standard vs. 1.88A on the MM, so it's obvious the mod is working.
Can I swap the two emitters? Is it easier to unscrew the assembly or desolder the board? I couldn't get it to unscrew in the 10 seconds I tried with a set of needle nosed pliers.
TIA.
TIA.
