Steelwolf
As I understand it, a zener diode is designed to be used as a voltage regulator. (or a current regulator depending on design). You place it in reverse polarity to the current flow, and it only allows a certain specific voltage drop across its terminals.
So if I had a memory cap I didn't want to fry, I would put the memory cap terminals in parallel with the terminals of the zener so that the voltage across the capacitor's terminals remain constant?
What would this do to the current? Can I model it as a proportional converter? Or more specifically:
I have a handcranked generator. The faster I crank, the higher the voltage output. I could control the voltage by maintaining a certain cranking speed, or I could put a zener diode. If I were to feel energetic, I could crank really fast. Would the extra voltage be converted to current to charge the capacitor or would the current be shunted away?
What about after I stop cranking. Will the zener then allow or prevent discharge across it? Or the zener doesn't matter after the charging is done?
Thanks in advance.
Thanks in advance.
