As I recall, the typical "fry-oil" conversions start on diesel, get the engine warm and circulate radiator water around the
[fry] oil lines/
[fry] oil tank to reduce viscosity. Once warm, just switch over to the
[fry] oil. And, at the last few miles of the trip, switch back to diesel to purge the
[fry] oil
[from the injectors, pump, and lines] and get ready for the next cold start.
With Bio-Diesel, the fuel is transformed in a chemical reactor (and glycerin removed) by the conversion process/chemicals. The resultant fuel can be run like diesel in most engines (may still have issues in very cold weather--but so does diesel).
The other issue with non-diesel alternative fuels is that they are very aggressive on the flexible fuel lines. Many engines need their flex lines replaced. According to CPF member Ikendu, engines manufactured after 1995 should already use the synthetic lines and seals. Older engines may need conversion.
If you drive a lot, it might by nicer to do the cooking oil conversion as you will not need to process the oil--thereby eliminating the purchase and disposal of hazardous chemicals/waste. You do have to install a second insulated tank with a heat exchanger in your car.
If you drive short distances and/or don't want to convert your vehicles--then the bio-diesel process is probably the way to go... But, you will need a shed for the conversion/storage of your fueling station and a place to take your wastes.
With either method, you can still use regular diesel when the alternative fuels are not available.
For any more information, you will probably need to go the web sites associated with each. I don't have much more knowledge than what I just related.
By the way, "
ikendu" is the member here with the Bio-Diesel experience. Contact him, look for some of his older posts, or try his link at:
http://www.itsgood4.us/
I don't see how he missed this thread--he is very willing to help anyone looking for information/help. I see he has been posting lightly over the last few weeks and may have missed your thread.
-Bill
