D
**DONOTDELETE**
Guest
Well, I couldn't wait for my lamp to burn out so I made my own drop-in LED replacement for my E2. I made it out of a bic pen barrel, coax cable with the guts pulled out,two washers and lots of hot glue. Sorry I don't have the digital camera anymore. Maybe I can take some shots at work. First I took a round white barrel Bic pen and cut it exactly the length of the regular lamp from the metal washer to the contact end. Leaving me with a small white plastic tube. I then cut a piece of thick contractor grade coax cable the same length. I pulled the guts out leaving me with a hollow tube. I stuck this tube into the Bic pen tube. The cheap coax won't be big enough. You have to get the good thick stuff. You can do without the coax tube if you have to. It's just to make it a better fit. Take a white 5600mcd LED and cut the positive lead short. About a quarter inch or a little less. Take a 33ohm resistor and cut the lead of one end leaving a quarter inch of wire. Solder the resistor short leg to the short leg of the LED. Cut down the positive lead to a quarter inch and solder a piece of resistor wire to it. Just cut off the resistor and keep the wire. The lead isn't flexible enough. Find a metal washer the same diameter as the metal washer in the original lamp. The one I found had a center hole exactly the right size for the white pen barrel to fit tightly in. I stuck the white barrel in it so it was flush with the other side of the washer and hot glued the back side of the washer to the white pen barrel. Stick the LED leads including the resistor through the flush end of the washer down into the pen barrel. There should be a quarter inch gap between the very bottem of the LED and the flush side of the metal washer. It has to stick up this far to be able to extend all the way into the head of the flashlight. Hot glue all around the underside of the LED to the washer. Cut away any excess after it dries. The glue can't be wider than the LED if it is to fit into the head of the light. Cut a slit in the pen barrel almost all the way to the washer. File a notch in the washer edge by the slit. Pull the negative lead (the one without the resistor) down into the slit in the pen barrel and down the side and over the washer into the notch. Bend the lead over so it sits flat on the LED side of the washer. Now take a small thin washer a little bigger than the pen barrel and notch the outer edge on one side and make another notch on the opposite outer edge. Make a small slit in the pen barrel for the positive lead to bend over the edge of the pen barrel and stick out. Hot glue the small washer onto the center of the pen barrel lining up the notch on one side with the slit in the pen barrel and the positive lead. After it dries bend the positive lead over the notch and across the washer and down into the other notch. Then bend the lead under the washer and around the pen barrel just to keep it out of the way. You can glue it to the side of the pen barrel if you want. Just don't let it touch the negative lead that's there. I know it's hard to picture with just written instructions. I'll try and get some pictures of it from different angles so you can see what I'm talking about.
What's nice about this conversion is that I didn't have to modify the flashlight in any way.
I take my regular lamp out and drop the LED lamp in and I've got at least 26 hours of nice LED light. The reflector on the E2 is great for LED. It makes a nice bright smooth and round circle of light. It's plenty bright. Several times brighter then my white Photon. The circle of light is about 10 times bigger too. After doing all this I still think it would be easier to just take a burned out E2 lamp and replace the bulb with an LED. You might want to just wait till your lamp burns out instead of messing with all the glue and washers and stuff. But if you can't wait, give this project a try. It was a fun one. I'm still planning on getting the high output lamp too. Then I can switch between low (LED) medium and high depending on the situation.
I reworked the project 4 times until I got the brightness level I was looking for.
Here are the resistor values I tried and the mA output of the light. At least peeling off the glue was easy with the hot glue. Resoldering the resistors was kind of a pain though.
10 ohms 110mA
22 ohms 75mA
33 ohms 50mA
47 ohms 35mA
I finally settled on the 33 ohm resistor with a nice steady 50mA output.
Nice and bright and I don't have to worry about the LED blowing out and leaving me in the dark.
I really like the push button on the end for a quick burst of light and the twist on end cap works really smooth. This is my new favorite carry everywhere flashlight.
Brad
10 ohms 110mA
22 ohms 75mA
33 ohms 50mA
47 ohms 35mA
Brad
