randyo
Fenix is getting all the "buzz" with their recent releases, but I wanted a Phoenix instead. I had one of CPF's premier Modders perform his magic on a recently acquired Arc-AA "dead-head". My dead-head Arc-AA "Rose From The Ashes" What I requested and received was a 2-stage, with a 1.5W high setting and a custom 90mA low setting. The reflector was parabolic cut (as much as possible given the limitations of the available tooling), and of course polished. What a beauty! The "Low" setting is very similar to the output of a River Rock 2AAA in intensity (with a much nicer color of course). The high is more than you would ever expect to see coming from an Arc-AA. The "High" setting is probably more light than you'll need, since the low is so functional. It's at least equal to a Fenix L1P, but the hot-spot is broader and flows more smoothly into the remaining beam, and is broader than an L1P by around 20%. That's more ouput that I'd hoped for given the HUGE advantage that the L1P has in reflector size, shape, and material. I find it more pleasing to use, as sometimes the beams with too much hot-spot can be annoying to use. The light makes a great hand-warmer too - leave it on for 20 minutes or so and you'll be moving it back and forth like a hot potato - unless you enjoy holding 140F! Sucking darned near 2 amps from a AA cell WILL generate some heat. It appears the heat-sinking is working very well. Words can't describe what a joy this light is to hold, use, play with, and just take out and fondle!
MY PRECIOUS!!!!
MY PRECIOUS!!!!
