Nite Ize Circuit
RCatR
Western NY, USA
Does anyone know the specs on the Nite Ize circuit?
because of the cheap price I was going to buy one and use it to possibly drive 3 red and 2 UV led's
any tips?
mahoney
Your red LEDs and your UV LEDs are likely to require quite different forward voltages. It will be challenging to drive both types from the same circuit. If I wanted to create a flashlight using Nite-Ize modules that put out both red and UV light at the same time, I would buy a red module and a blue,white, or green module and I would replace the blue/white/green LEDs with the UV LEDs. Then find a 3 volt host with a head big enough to contain both Nite-Ize modules, perhaps a Garrity Stainless, or any plastic 2 D cell flashlight.
perfectname
Bainbridge Island, WA
If you are using two cells (NiMH or alkaline) you could use the Nite-Ize for three of the UV LEDs and then run some red ones straight off the batteries with a resistor since they have a lower forward voltage. You can get the Nite-Ize modules for only $5 so I'de say get one and give it a try. I had a couple of them but I couldn't figure out how to take them apart non-destructively. Good with your project!
