ElektroLumens
I have been working on a little project for a while. With the help of an expert in optics, I have designed an adjustable beam Luxeon Star modified flashlight. I mounted a bare emitter Luxeon Star LED on a heat sink plate, and used 2 different lens, to provide from a wide angle beam like the present optics afford, to a very tight and narrow beam which easily goes 100 yards. I am going to put a beam shot pic so you can see the difference in beams, on the left is a the current blaster, a 3 'D' cell direct drive job, which is very bright. On the wide angle setting of this adjustable beam LS, it is about the same. On the right is the adjustable beam flashlight, which I think I will call the 'Nova', with a tightly focused beam. The beam shot is from about 15 feet away.
Wayne
Elektro Lumens, doing the undoable!
Wayne
