Same happened to me. The small section on the bottom of the head came apart by hand (really twisting), but no matter what I did, the head would not loosen by hand, and I made my hands hurt and bruised for a day ( I do not bruise easily!) trying. Until I broke out the strap wrenches. It is not easy to do the first time, because you have to take some care to tighten them very well so they don't slip. But then... twist (make sure you are UN-screwing - easy to mix it up with all the tools covering the entire head/bezel) it just comes apart. There is NO WAY the head will stand up to properly tightened strap wrenches. It would have to be soldered or welded together. You just have to pull the straps as tight as you can get them, and they will get it open. I've opened my Q3 and my Big Q3 this way.Mr. Bombastic said:I've been trying to open the head of my big QIII for ages. Been using boiling water (with the light in a bag for 10 minutes) and two strap wrenches. It just wont budge!
A section under the clip came unglued though. However, this doesn't let me access the LED at all, just the top of the battery tube.
