mercanucaribe
- Joined
- Jun 4, 2006
- Messages
- 10
Question 1: Why use 3xAAA? A single AA (2400mah) contains the same power as three AAA cells (3x800mah), takes up less space, and weighs less.
Simple math if you want to think about them in series instead: An AAA nimh cell is 800mah, and an AA cell is 2400mah. The voltage of the three AAAs in series is 4.5 while the single AA is 1.5.
4.5*800mah = 3.6 watt-hours
1.5*2400mah = 3.6 watt-hours
Yep, the voltage is different, but that's irrelevant since an LED can be made to run at any voltage desired.
Two AA cells take up about the same space as three AAAs and provide twice the power.
Question 2: Do 3xAAA flashlights run the batteries in series or in parallel? If they are parallel, I figure it shoudl be easy to mod such a flashlight to use a single AA or maybe even a C cell.
