I just wrapped up building a "Luxeon pill" that drops into a Brinkmann AA flashlight. I chose the 3AA body because I wanted to direct drive the Luxeon off of 3 Ni-Mh batteries to get 3 x 1.2v = 3.6v I like the efficiency of direct drive plus I don't possess the electronic genius that some of the other guys here do.
I chose to build a pure copper heatsink which was bonded using Arctic silver thermal expoxy to the original LS/o aluminum heatsink. Using the copper also allowed me to solder on to pick my negative lead. I built a center post from some non-conductive washers with a center stud to route the positive lead.
I can't begin to say how ecstatic I am about how this sucker blasts light !! Comparing it to an INOVA X5 if was hard to tell the INOVA was even on!
My Lightwave 3000 didn't fare any better.. Starting with the Ni-Mh's I'm getting the following results:
* Freshly charged-
4.05 volts
1.120 amps
* 10 minutes run-
3.74 volts
980 MAh
*15 to 20 minutes run-
3.67 volts
850 MAh
Did I mention this thing is bright? darn near "permanant eye damage" bright..
I'm also extremely impressed with the thermal stability of this flashlight so far, even though I haven't conducted any continous run-time tests. I'm convinced the copper is responsible for this since even when the flashlight head becomes warm, removing the pill I find that the temperature appears to be lower than that of the surrounding metal. The above readings are stated at approximatly 10 to 12 seconds run where the readings stabilize cleanly. Testing with alkalines will happen (4.5v) but I intend to build up to that slowly, as I'd just hate to fry a creation that took so many hours to build.
So does any one know if a well heatsinked Luxeon will survive 1.5 amps @ 4.5+ volts??
With the freshly charged Mi-Mh's, I found that consumption began at 930 MAh and climbed steadily to 1.15 amps before "settling". I plan to use the Ni-Mh's for their rechargabilty, but would like to dertermine If I can get away with the alkalines (extra power) without taking a big chance that I'll fry it..
I might also add that inspiration for this mod came from a combination of Lambda's work with his Brinkmann "Illuminator" + Electrolumen's work on the "Blaster" Mag along with some collaborative conversation w/Mr. Bulk. Thanks to you guys (and the many others) who take the time to share with all of us.
* Freshly charged-
4.05 volts
1.120 amps
* 10 minutes run-
3.74 volts
980 MAh
3.67 volts
850 MAh
