D
**DONOTDELETE**
Guest
See latest post below.
With generous help from the almighty Lambda, and after stumbling through some initial novice-modder trials and tribulations (like hey, how come nobody ever told me the LS tabs could keep breaking off that easy???), I finally turned out an LS mod of my own!
Left picture is a beamshot of this Grasshopper's Legend 3AA DirectDrive (above) overwhelming his Sensei's own vaunted Lambda Illuminator:
The white Legend bulb socket was kindly sent to me from Lambda with the wires already soldered into their negative and positive slots (a very difficult job to do without creating total meltdown of the plastic socket itself), so all that was left to do was the spacing and fitting of the mechanical bits and a few "easy" soldering points, along with the Arctic Silver epoxying tasks, and *Presto*! The LGI (Long Gun Illuminator) was born.
A word of warning however, this baby gets quite warm, quite fast. Fine for my line of work (quick spot checks where intensely white color-accurate light is flashed for a minute or two at a time), but if I need to use it for longer periods, I may do like Elektrolumens and go with rechargeables...along with an obviously perceivable reduction in brightness.
THANKS, Kevin!
THANKS, Kevin!
