mccavazos
I was attempting to replace the LED from a TW0J to a UW0J on my prized longbow Micra, and I ran into a bit of a problem. I used solder wick to remove the solder on the pads for the led and the attached wire. I removed the TW0J without any problem and placed the UW0J in. I then fired up the light, and no light. I quickly turned the light off and switched the Leads (assuming that it was just a miscalculation on my part. I fired up the light again, and again no light. I then assumed that my R123 was dead so I went a grabbed a primary and once again no light, but this time the battery got very hot. I disassembled the light. There is no apparent physical damage to the McCapsule that I can see, and all of the exterior connections look good. Is it possible that the board melted when I was desoldering the leads? Maybe some solder inside the capsule flowed? The inside is incased in thermal epoxy, but this was my first mod, so I guess that there could be air bubbles in the epoxy. My iron was on 700 F and it was able to get the solder off very quickly (I build robots as a side hobby and therefore am very good at desoldering ).
