Sunstar - I have AW's new protected 17500 and 17670 cells that I run in a M3T (17670's with an extender, obvioulsy
A couple of the 17500's need a double click but most of the cells light with a single one, but with the LOTC in place its not a problem with the double click at all and i'm using this set up as a duty light.
Dont think you'll get anything like 40 mins on an MN16 though as suggested above, thats more like the run time for a MN15.
Before I bought the turbo head it was a stock M3 and I was trying it with PILA 150S's but this gave a lot of problems, needing an extra spring round the LA and it was still not reliable then even with a clickie tail cap which did improve matters slightly. I had given up using it for a duty light until the 17500's cells came along, these are slighlty shorter and the proper battery type positive contact makes all the difference and a very reliable duty light.
I can see no difference in output against primaries except that you use it a lot more cos its free
