RofisLight
Results 1 to 4 of 4
Thread: Brinkmann 2AA head inner diameter
    Jun 2001
    Berlin/Germany
    Default Brinkmann 2AA head inner diameter
    Here they are:
    A LS/o, a brinkmann 2AA, Li-AA´s, a soldering iron, some wires, basic mechanical & electrial skills.
    Sounds like the beginning of a nice evening doing some "novice-level" modding, right? [img]images/icons/smile.gif[/img]
    Now, just imagine the expression on my face when I checked the Brinkmann´s head inner diameter.
    Had a good laugh? Ok, then further on [img]images/icons/grin.gif[/img]
    The LS/o just won´t fit ( ok, maybe if I´d try the largest sledgehammer I can find it will ).
    Is there any way to determine the inner diameter of a Brinkmann´s 2AA head from the outside ( packaging, colour, accessories ) without opening the package? At least over here, they only come in this nasty kind of sealed blister-pack that Craig likes so much [img]images/icons/grin.gif[/img]
    TIA
    Seth
    Jun 2001
    Berlin/Germany
    Default Re: Brinkmann 2AA head inner diameter
    Tnx a lot, Wayne!
    I guess I´ll just have to find someone with the proper tools to go the "first way".
    Believe it or not, but it´s real hard to find a LS over here, not to mention a Legend 2AA.
    So, using a "pill" ( where to get bare emitters? Ouch... ) or simply buying another 2AA isn´t the way to go [img]images/icons/tongue.gif[/img]
    A hint for all other LS-fanatics over here in germany:
    You can get them from ebay here :
    LS/o at ebay.de
    Ledsys is a quite friendly guy, and if you have some patience with auctioning, you can get your LS at prices that won´t differ too much from prices in the U.S. [img]images/icons/smile.gif[/img]
    Hey, don´t say that was easy to find... it was me who asked ledsys to include the "Luxeon Star"-keyword in his auctions [img]images/icons/grin.gif[/img]
    Seth
    Flashaholic* Slick's Avatar
    Apr 2002
    Nor Cal
    I built my Brinkmann "pill" for the small diameter head using a LS/o.....or you can use a bare emitter - either way works great.
    Here's photos of the Brinkmann AA mod I built.
    Flashaholic* ElektroLumens's Avatar
    Jan 2001
    Cottage Grove, Oregon, USA
    Hi Seth,
    It seems the Brinkmann AA flashlights used to have a smaller inside head diameter . I had one sitting around for about a year. I found out the most recent AA flashlights I purchased have a 3/4" inside diameter, which works quite well for mounting a 3/4" disc in, and a collimator. The spacing fits perfect, like it was designed specifically for this kind of mod.
    There are 2 ways to use this older design with the smaller inside diameter. One is what I did mine. I used a 3/4" drill bit in a drill press, and machined out the inside to 3/4". You must remove the rubber on the outside of the head, and holding it with plyers works quite well. Just ream out the inside, but leave about 1/2" of threads for mounting the head.
    Another way is to make a pill, direct drive. I just did it this way in one flashlight, to see if it would work, and it did. It can be turned on and off by twisting the head, or by using the tail cap switch. You only need to remove the reflector from the head and install the collimator in it's place, and screw the head on until it contacts the LS. This works quite well too.
    If you have a drill press, the first way works quite easily. If you do not have a drill press, the second way also works quite well.
    I cut the heat sinks using a hack saw and a bench vise. This is the hardest part of either mod.
    Wayne
    www.elektrolumens.com
