Yesterday I was trying some new heat sinks with my red BL3000. The sink I had was adequate enough to cool the LED for a short time but I guess I didn't put enough thermal grease between the junctions of the heat sink and the LED. Anyways, I turned on the power supply and slowly juiced it up to 6.7 volts (normal running voltage) when after a little bit I noticed some activity on the array. A few of LEDs where blinking and some shut down!!! So I killed the voltage to it right after I noticed it. I put the array back on the old sink using the same grease (very thin film of it by now) and turned it back on with low voltage. The whole array was running stable but I had it down low, as I turned it up it seems that now only one led was "shutting down" and by pressing my finger on it I could absorb some of it's heat and it would turn back on. I'm not goanna run it anymore until I get some more grease (hopefully tomorrow) and ill post the results. But what would cause this??? I don't know how badly I damaged the (Ga, In) crystals if that is even the case; they are all still the same color and intensity. Maybe it was the traces on the PCB expanding from the heat??? Anyhow... do ya think I ruined my BL's life expectancy??? Because whatever I did it can't be good.
I loved that thing.... (stupid me!)
Great thanks to all of those who can answer with Intelligence or experience!
