I picked up a 12 volt, 20 Watt bulb for an experiment. This is what I did.
First, I used 3 of the battery tubes from the 3C Radioshack aluminum flashlights I picked up, and stuck 8 C batteries in the extentioned tube, with extra spring to make up for the extra space. I hooked up the 12v, 20W bulb and then (when it became dark outside) I took it, along with my Brinkman LX outside for a little test. I was a little surprised by my discovery. The Brinkman LX was still a little brighter, and much whiter.
The question is, since this was just an experiment (done just because of the ability to attach battery tubes from RS flashlights), and since I assumed that the 12v, 20W bulb would have the proper amount of voltage from the 8 C size batteries, was my initial hypothesis wrong in that it would be an extremely bright flashlight? I mean, you can imagine the length of this flashlight, and since the Brinkman LX is a fraction of the size, with better light, I can only assume that I did something wrong, or hypothesized wrong.
