Is this a bulb with 6 luxeonIII's?: http://www.circuitspecialists.com/prod.itml/icOid/8763
It is expensive but it would be SERIOUS output if used in a 2C Maglite.
Specs:
eLUX™ is the only state-of-the-art programmable LED technology for Maglite® flashlights. Light lumens (LUX) are generated electronically (LED) instead of from heat as in a traditional bulb. LEDs are virtually indestructible with no hot filament to burn out or fail from shock- outlasting original incandescent bulbs by over 100,000 hours.
- Wide Angle flood beam
- 3 x White = 175 lumen / 6 x White = 350 lumen
- Latest generation high power quartz LEDs
- Machined billet aluminum Lens/Heatsink
- Two-Mode operation
- Consumes near 12w (6 LEDs full on)
- NiMH batteries recommended for improved brightness and runtime
Multicolor eLUX™ LED replacement bulbs fit any C or D cell Maglite® flashlight. Microprocessor power pulse regulation "squeezes" an additional 140% of power before discarding batteries significantly extending flashlight runtimes.
eLUX™ bulbs utilize exclusive DPLM (Digital Programmable Light Modulation) technology. They are the first and only LED conversion to offer full programmability, true regulated hue/brightness, near 90% energy efficiency and 3-in-1 color bulbs.
Design Advantages:
- LED bulb array lasts 4000% longer then factory 12 hour incandescent bulbs
- Latest generation "true" white LEDs
