FlashKat
Hello fellow U2 Owners,
The following is only to try on U2 tailcaps that have clickie problems!!! I just wanted to pass on the information and there is no gaurantee it will work.
I just bought my U2 and everything worked perfectly!!!!!, but out of curiousity I tried to lubricate my tailcap switch with some silicone grease to prevent future jamming and it started jamming up.
I then sprayed Caig Cailube MCL to flush out the silicone grease (Keep in mind this is all done without disassembling the tailcap), and let the tailcap dry out over night and it works perfectly again. You propably will have to work the switch in and out a few times to get it moving smoothly.
Caig Cailube MCL is designed for plastic moving parts, but be careful you need to get the excess Cailube out and let it dry out overnight, or it will jam up in between if excess is not dried out.
