OutdoorIdiot
Sorry about the ambiguous title of the thread, but I'm not sure exactly what the issue I'm having is. It could be something to do the the SF G2 Nitrolon, the P61 lamp assembly or the thermal shutdown of (SF) CR123 cells (or all three).
If someone has experienced this combination, i.e. thermal shutdown when running a P61 in a G2 Nitrolon, then you may be able to help verify some things:
I've just been running this combination flat-out in an attempt to get some data for the thread about LunarModule's exploding PM6. I don't normally push things to the limits, and so have just experienced some things I'm not familiar with.
Specific questions:
(1) At 12 minutes runtime (fresh, "matched" batteries), output dimmed from bright to off in about 4 seconds. I turned it off, let it cool for about 20 minutes, then it was able to produce bright light again. I expect this means that one or both of the batteries had entered thermal shutdown. Does that sound right, i.e. is thermal shutdown a process that takes place over a few seconds, then resets in a relatively short time if the batteries are allowed to cool?
After it had cooled, I took the batteries out and there was a very powerful smell which I am not familiar with. It smelled nothing like the solvent smell that is common with CR123s. I would describe it as acrid and overpowering. I vented the room and left it for about 20 minutes, after which it was tolerable. I inspected the batteries, and there were no signs of leakage or damage. I checked voltage and "flash amps", and both were AOK. After separating all the parts of the G2 for a while to let them air, it seems that all parts, and the batteries, have this horrible smell - making it hard for me to work out where it is coming from. So:
(2) Is it typical for CR123 batteries that get very hot, or enter thermal shutdown, to produce an acrid smell?
If anything, the smell seems to be strongest at the bulb. I've also noticed a blob of solid white stuff where the central spring connects to the lamp assembly. I hadn't noticed it before, and by contrast, there isn't one on my P60. It looks like it may be adhesive that I just hadn't noticed before. So:
(3) Can anyone with a P61 confirm that thay have this white blob?
It could even be that this white blob is adhesive, and it just got so hot that it has produced this awful smell. It may even be the Nitrolon body, because the smell is so pervasive that it comes from the whole external length of the tube - though I doubt this, because I didn't notice the smell until I first opened up the G2.
Anyway, most general question of all:
(4) Has anyone else experienced this or something similar, and what did you conclude had happened?
Thanks in advance.
Specific questions:
Thanks in advance.
