ElektroLumens
Thanks to Mr. Bulks generosity, I have a few of those 1" acrylic balls. I mounted up one of the brightest high dome Lambertian Luxeon Star emitters I had received from Lumileds onto a Blaster. This emitter is rated at 25 Lumens at 350mA. I wanted to do a test of this emitter with the acrylic ball, and so I did. With the ball right up to the emitter, and 1" away from the meter, I read 19,500! Can this be real? Okay, so then I take a reading from 1 meter away, and I read 1,840 lux! About 3 times brighter than any other Luxeon Star high dome I have tested!
I take this thing outside, and it projects a square, very very intense beam, easily lighing up objects 200 feet to 300 feet away, very bright!
I also found out something else very interesting. I mounted the optics, (newer style), in a black optics holder, and held it up to the emitter, but trying to see if I can focus the light better, and it does. If I hold the optics out about 1/8" to 1/4" away, it gives an even flood of light. It seems to better capture the wasted side emitter light, and puts it all together into a single bright flood. I will try to get an exact measurement, and just put a spacer in between the heat sink and emitter holder, from now on. Sorry, I didn't test this brightness, but I can do so tonight.
I did all testing without any background light, as I was in a dark room with the door closed.
I have taken readings from other Luxeon Star high domes, and got at the most 600 lux from 1 meter, so this thing is the brightest emitter I have ever had! Even if my readings are not perfectly accurate, it gives an idea of how incredible this thing really is.
Wayne J.
www.elektrolumens.com
Wayne J.
