Hi guys,
Some initial impressions of this light -
It's smaller than I expected, the same diameter as my Raw NS, and onlya cm or so longer (it's a head taller).
The brightness is not bad at all, though even w/ the whole 'flood v/s hotspot' thing factored in, the overall output looks (at least to my eyes) to be noticeably less than my raw ns.
Speaking of hotspot, don't believe the reports on here that it's a pure flood w/ no noticeable hotspot - there is a noticeable hotspot, but it's smaller than on other lights, and the contrast b/t hotspot and spill is less. but it's not an even flood throughout - so if you were looking for that (which I was) adjust your expectations accordingly.
Another thing is, is that from low to high, you need to turn it more than 180 degrees around, about 220 or so from my rough measure. In hand, twisting it w/ finger tips while holding w/ palm, that means for me three normal twists, or two big twists. This doesn't have to do w/ the tight o-ring, but just about how many times around it needs to go. Personally I like the tight o-ring, b/c it feels more sturdy and probably better sealed that way.
Finally, I haven't had this issue on any of my other lights yet, but I like to turn off my twisties 'just so' - i.e., stop turning just when it turns off. But on the Ion, when I do that, I think b/c of the two-stage mechanism, when it jiggles around on my keychain it turns on and off. so, I have to turn it off a good full single twist past the 'off' point. I'll get used to it I'm sure, but it's a noted point of difference from my Raw NS as well as my clone AAA.
How does this compare w/ the rest of you guys out there who have Ions?
As for me, jury's still out on whether I like this guy or not. If it had been a true full and even flood, I would be all over it. But (as Enrique confirmed to me yesterday) that's not what the Ion's beam is like. He suggested I put some diffuser film on the front and I may try that. But, that seems to defeat the purpost of shelling out for an Ion, when I could put diffuser film on my Raw NS. Comments?
