geepondy
I have a mini-mag badboy500 module with an original low dome luxeon that I use at work. I love the wide area output of the low dome as when I'm doing close up inspection, it covers a lot of ground without having to move the light around. However I'm not crazy about the other aspects. You have to unscrew the mini-mag head in order for it to operate and sometimes the operation can be quite a bit flaky and also the module will fall out when replacing the batteries.
Any modern day equivalent with a more polished carrier, prefereable with a clicky switch? I have a Fenix L1P and thought about a L2P but even that light output is considerably more narrow then the Lux low dome. I would much prefer an AA type of light if possible. I know several weeks ago I asked about work light replacements but in specific I want something with the same beam charateristics.
