If you're referring to this one:WNG said:Their 15-LED 3D is about the size of a Mag, but it's pure junk.
The LEDs are dim, and the bezel/head is stamped, can't access the reflector/lens
Wasted $19.
DrMaserati said:If you're referring to this one:
http://www.harborfreight.com/cpi/ctaf/displayitem.taf?Itemnumber=94524
I just bought two of them last week for $9.99 each. They work great and are quite bright, well worth the price. The head is not stamped, it is machined, and the LED/reflector unit and lens are easily removed by unscrewing the retaining ring inside the back of the head. You will find that the head is two piece and comes apart at the hexagonal rubber ring. You will then see the retainer holding the LED/reflector unit in place.
What kind of switch does yours have? Two position means "on" and "off." What does your's have? What is the HF item number of yours?WNG said:No, that's not the one I have. Mine is older, no two-position switch, but looks just like the one above.
The new one may be better, but avoid the standard one.
