Malkoff
Page 1 of 5 12345 LastLast
Results 1 to 30 of 126
Thread: Introducing "PES2"
    Flashaholic* modamag's Avatar
    Aug 2004
    Bay Area, CA
    Default Introducing "PES2"
    Guys, I have spent numerous hours designing this.
    Yep ... just a bunch of circles.
    Anyone care to guess what it is?
    The first three to guess correctly and will get one free.
    Only three simple rules:
    1. Your guess must be posted in this thread. No PM, no email and definitely no phone calls.
    2. Only one guess per CPF member. Don't try to register multiple CPF handle. Sasha and the admins will boot all of us.
    3. You have to be "specific", you can't just say "it's a thing" that doesn't count. If it's a pheasant, you got to tell me it's a chicken, duck or turkey.
    It may or maynot have anything to do with flashlight.
    It looks like bolt pattern for a stunt kite to me
    Games winner announce when Draco pricing announce. You may change and edit your guess at anytime.
    Default Re: Introducing "Guess This"
    Cut-away view of a Wankel engine?
    Okay, maybe not.
    *Flashaholic* IsaacHayes's Avatar
    Jan 2003
    Missouri
    Man you are killing me! It's a heatsink. Reflector with holes for 3mm leds to poke through? It's a aahh *crawls back into hole*
    Mags: 2C: R/O, True Cyan, UV. 3C:Penta-XR-E Q5, Single SSC P4. Nitecore D10, Fenix LOD-CE, ArcAAA
    Nov 2005
    rising sun
    Battery contacts
    Flashaholic* TENMMIKE's Avatar
    Jan 2006
    puyallup WA.
    its the front end( bezzel end) of a flashlight that has multi colored led array around a main emitter ............
    any hints? like size, metal or plastic....
    right now i'm with Mr. Hayes.. looks like a heatsink, but that would be too easy...
    Battery tube with contacts for 4 or 3 cell "groups" with a center "pole".
    Jan 2003
    Missouri
    Multi position rotary switch for a varible brightness or strobe/etc flashlight. Twist to select different settings.
    Nov 2005
    rising sun
    I think battery contacts.
    Jul 2002
    Finland
    It sure looks like battery tube with many cell size options:
    positive battery contacts for:
    1 D-size, 3 AA-cels and 4 AA-cels
    and if tube is large enough:1D, 3x18650 cels or 4x123
    Juha
    Oct 2004
    Hong Kong
    Thinking Re: Introducing "Guess This"
    Top view of a reflector ( bezel ) with main bulb opening and various openings for LEDs.
    Jan 2003
    Missouri
    Jumi: I THINK YOU'RE RIGHT!!!!! Wow good job!!! battery adapter to hold 3 or 4 cells!!
    I'm with you on this one!!
    EDIT I changed my mind!!!! I'm Not with you on this one!!
    Back to my original first repsonse. Heatsink. For 3-4 emitters. Has walls with cut outs for the 4 reflector setup. It's like a PTS/PQS v3 all in one!! Luxlunatic is right!!! I did say heatsink in my first post, but not the details... does that count!?? hah
    Flashaholic* luxlunatic's Avatar
    Feb 2006
    SoCal
    Looks to me like a combination PTS/PQS for emitters(you choose the application). Maybe I'm just dreaming of the D size PQS that I need !!!
    What are you people......on DOPE!?!
    Flashaholic* Somy Nex's Avatar
    Sep 2005
    Penang, Malaysia
    I'm with Jumi, Shaocaholica and Isaac on this, it looks like a battery tube / power pack, that accepts a wide configuration of batteries, either 1, 3, or 4 (especially with what look like 4-bored out sections).
    edit: actually it might not accept a 1-battery configuration as that middle one looks like a hole. maybe an opening for a charging plug or a positive contact maybe? =P
    Somy Nex
    Flashaholic* Sway's Avatar
    Aug 2003
    North Carolina
    Shower Massage Head with therapeutic LED's
    Lucas Jackson, "Here, Captain"
    Maliciously destroying municipal property while under the influence, What was that?
    "Cutting the heads off parking meters, Captain."
    Jan 2003
    Missouri
    Kelly: that would rock!! however I don't think you're right... But maybe that should be the next project!! I'd love selectable led color shower head at night. I shower with no lights on at night frequently. That would be cool!!!
    I do need a PQS to build a quad-true-cyan light..... I was thinking C sized light this time. 3C mag DD nimh sounds good, with a custom flu-pig for strobe/pulse/throb/etc
    *Flashaholic* bwaites's Avatar
    Nov 2003
    Central Washington State
    It's a heat sink to hold various combinations of LED's.
    Bill
    Only a virtuous people are capable of freedom. As nations become more corrupt and vicious, they have more need of masters.
    Benjamin Franklin
    It is a heatsink made to remove the need for PQS/PTS and Hotlips-style heatsinks in one :-)
    In the middle you got a little pedistal where you can put a single luxeon to use with the mag reflector,
    then you got three positions for luxeons that sits a little nearer the center than the quad ones because of then you can fit the (3*20mm?) reflectors,
    in the quad setup cutouts are made in the wall for the four reflectors...
    Am i right ?
    Flashaholic* AuroraLite's Avatar
    Nov 2004
    HK
    The new contact plate for the new Modamag battery pack, which will allow different battery setting(most likely to be AA or AAA)?
    Dummy Reference Guide to Minimag mod
    Flashaholic* chevrofreak's Avatar
    May 2004
    Billings, Montana, USA
    It does look as though it's a 4xAA or 3xPila 300A/S carrier to me. Regulator circuit in it perhaps?
    Hi,
    this is a new heatsink socket for PIR or HotDriver.....
    Flashaholic* chimo's Avatar
    Sep 2004
    Ottawa, Canada
    Looks like a heatsink that will accept 3 or 4 emitters.
    Flashaholic Taylorf's Avatar
    Dec 2005
    Missouri
    Some kind of custom reflector for a Maglite.
    My small collection: Surefire 8ax, Orb Raw, Costco 10 million and 15 million, Streamlight Ultrastinger, and the Exolion
    Flashaholic Barefootone's Avatar
    Jul 2003
    East Brady, Pa.
    Wink2 Re: Introducing "Guess This"
    I think it's a reflector mock-up for LED placements.
    ~ I've lived to see another sunrise ~
    ~ Kicked cancer's ass 3 times~
    Flashaholic* Cliffnopus's Avatar
    Jan 2006
    Foxboro, MA
    It's an ancient titanium coin from the Flashazoic Era.
    Cliff
    Every normal man must be tempted at times, to spit on his hands, hoist the black flag, and begin slitting throats!
    H.L.Mencken (1880-1956)
    Well, you all have guessed my battery holder contact plate idea(which was suggested to me by the ID of the originator, the hole in the middle, and the semi-circular cut-outs in the outer ring)...so I'm going to go with a pie-in-the-sky guess:
    This piece is the cover plate for a new type of intelligent flashlight switch--it had an up and down dimmer, and multip;le setting options controlled by differnet buttons.
    Hey, I didn't say it was a good guess!
    Flashaholic Rando's Avatar
    Apr 2006
    Indianapolis, IN
    I'm going with flashlight body to use 3 or 4 batteries quad bored.
    Flashaholic* Lurveleven's Avatar
    Dec 2004
    Bergen, Norway
    I'm quite sure it must be a 4 level rotary switch for selecting light levels. It is located at the tail and on the other side there will be a button. The identations will help the switch to stop at the right position so that the contact points will mate with the contact point on the circuit board. That the switch stops when it enters a level gives the switch a great feel, those of you who have a Stenlight headlamp know how nice switches like these are in use.
    Here is how the contact points on the circuit board should look like:
    Sigbjoern
    Flashaholic* chesterqw's Avatar
    May 2005
    singapore,jurong
    i changed my guess. i think it is a thing use for charging of the batteries inside the draco.
    the circles and the hourglass shaped thing is uses to connect to the batteries. the center hole is used as a hole for the charger's plug(not sure how to explain) to go in.
    if killing was legal, i would have killed countless number of people...
    Jan 2006
    Bartholomew County IN
    I guess that's my(our) new toy.
