NITECORE -- Keep Innovating
Results 1 to 10 of 10
Thread: where to buy SMJLED
    Nov 2004
    Ontario, Can
    Default where to buy SMJLED
    I"m looking to get a smjled or smilliar 5mm led.
    Looking to run this on one or two button cells.
    where is the best place to get the smjled?
    Thanks in advance.
    What we have here is a failure to illuminate.
    Flashaholic* Newuser01's Avatar
    Jun 2006
    concord, ca - eastbay - US
    Default Re: where to buy SMJLED
    Quote Originally Posted by Rogue_monkey
    Thanks in advance.
    Here you go!! Link:
    I got 2 and its great!!!
    RE: Just re-read your post and this is not what you wanted. Sorry.
    But he may have them. PM and see?
    Regards.
    newbie!!
    Flashaholic* LumenHound's Avatar
    Apr 2005
    Toronto
    Lamda had them but he is sold out. You can order the un-cut version of them from The Sandwich Shoppe.
    Super MJ Led (4-die)-Uncut
    There is also a similar 5 mm led produced by WahWang that CPF member Tritium had for sale. He is closing out the last of them in this thread.
    Flashaholic* LEDninja's Avatar
    Jun 2005
    Hamilton Canada
    Sandwich Shoppe is showing both cut and uncut SMJLEDs. He's got some of the older MJLEDs as well.
    http://theledguy.chainreactionweb.co...cPath=48_52_82
    Flashaholic* Paul6ppca's Avatar
    Jun 2006
    RI
    Try this link,I was looking earlier this week and ordered 5 of these.
    http://www.candlepowerforums.com/vb...ad.php?t=119498
    Do these work well in a coin cell light? I have a bunch of them that I was hoping to swap the LED's in.
    Jun 2006
    RI
    I can let you know soon ,that is one of my plans,to replace in a coin/keychain light.Just remember they only want 3v, not 4.5v or 6v common on coin lights.
    Apr 2005
    Toronto
    If you use a pair of CR2016 coin cells it works out well. The 2016's are so wimpy that the large voltage drop across them under load prevents them from overdriving the led.
    Flashaholic* voodoogreg's Avatar
    Apr 2003
    Global
    what is the performance differences between the cut and un-cut? VDG
    "In nomine Patris, et Filii, et Spiritus Sancti."
    "lumen Gentium!"
    Apr 2005
    Toronto
    The cut version has a wide 180º viewing angle and is suited for use with a reflector whereas the uncut version has a viewing angle of only 35º and produces a nice wide flood beam on it's own.
