2 (of many)things i dont really know how to do.
one is repaiing /soldering chains of battery pack cells, which are mig welded together or something to replace bad cells. i'm thinking either torch soldering or slicing a strip of that cut welded tab to insert into a female spade / slide lug and maybe hitting it with a hammer to seal the deal.
the other is micro soldering.. i got some 3mm chips
that may just need a robot to solder the things. i was thinking of masking off all but 2 opposite pins
so i dont get solder bridges. the maybe a coat of paint or adhesive after soldered to strengthen and insulte the new wire connection. then remask for the next opposite pair of pins.
please let me know if you have something that works..
