LATEST LIGHT METER READING, PLUS BEAMSHOT PHOTO VS. SUREFIRE M4 (see latest post at or near end)...
Although the 5-watt in a Legend LX was bright (699fc), I knew it was being way underdriven at only 6V (and probably less as the Sanyo 123s in it were kinda used) and I wanted to bring the 5W closer to its peak performance spec to see what it could do.
I got some very good technical advice from dat2zip and lambda about checking current and then stringing resistors together and testing at each step, but the whole bundle ended up looking like the grand prize winner in some boy scout knot-tying contest, plus I wanted focusing ability which meant everything had to fit through the reflector opening which was too small, and I didn't want to cut off any of the reflector to widen the hole because I'd lose some of the focusing range, and...well, you get the idea.
So I very carefully metered all my used AA batteries and came up with five that measured:
1.274V
1.241V
1,259V
1.499V
1.500V
for a total of 6.773V (I believe max spec on the 5-watts is 6.8V @ 700mA).
I had to build a gigantic heatsink with an extended post (or pedestal, as McGizmo so elegantly put it) to match the height of the stock incandescent bulb's filament so I could retain the focusing range for which the reflector was designed.
The end result was several good things:
1) it has full focusing range, from tight spot to wide flood (with the dreaded MagLite black hole, unfortunately)
2) this particular 5W seems to still be running well below its peak as it does not get hot at all (after being on for a couple of minutes, I unscrewed the head and found the LS/post junction was actually cool to the touch)
3) yet the dang thing metered 2130 lux at one meter, or 2130 foot-candles...
Anyway here are some pics of this jade-green Fire Breathing Dragon, note especially the beamshot pic on the ceiling in broad daylight at 12 o'clock noon, where it puts the original DirectDrive 6V 699-lux 5W cyan Legend LX to shame:
I know some people (Hi Ya Lambda, dat2zip, McGizmo, the other Wayne, et al!) are gonna cringe to hear me say this, but -- after the Arctic Silver completely cures, I'm gonna run it at extended minutes and check temps, and if it's still reasonably cool, I am going to FILL up BOTH of the 3AA battery packs with SIX fresh AAs (using five w/one dummy now) and let'er rip at NINE VOLTS!
(and hope like hell it doesn't literally become a Fire Breathing Dragon...)
1.274V
1.241V
1,259V
1.499V
1.500V
