I read through a number of threads about Maglites Drop in LED replacement. There appears to be a heat related problem with the LED replacement. I guess there is no place for the heat to bleed off the LED. The result of this is a drop in power, brightness after a period of run time. I happened to have a Maglite 2 C Cell around and decided to take a look at the set up. ( the D Cell Maglite switches do not come apart ) The heat sink I made started out as a 1 inch piece of 6061 Aluminum. The original piece is some composite material that will act as an insulator. There is one main difference in the piece, I made a flange on the bottom. This is where the tightening ring presses up against the switch when it is put back in the Maglite. That should provide a complete metal to metal contact from the LED all the way to the barrel of the Maglite. This set up allows the LED to 'float' in the switch, the same as the original. I put some grooves on the piece for greater heat dispersion.
The picture shows the piece and the original - and - yes, that is a regular bulb in there. I wanted to be sure I could do this before I buy the LED replacement.
