cheapo said:as would the u2.
-David
skalomax said:Wouldnt the E1L,E2L,L1 all outhrow the HDS because the Optics. Also the New KL3 will Destroy the HDS in throw.
Blindspot said:I doubt the KL1 can out-shine the HDS, but I don't have one on hand to compare. Regarding the KL3 - I have no experience with that head, but it is rated at....19 lumens? Is this right? How does it kill the 60 lumen HDS?
270winchester said:optics have come a long way my friend....
Blindspot said:I'm not unfamiliar with optics. I generally prefer lights without optics, and am considering converting my Stenlight to a new reflector and no optics. That said, if the KL3 is putting out 19 lumens and the optics are responsible for throwing those 19 lumens really far - whoopie. I have a cheapo River Rock with optics that can put a circle of light way the heck out there - no spill at all and more or less useless for my purposes (I know - the RR is junk compared to any SF, but you get my point. :naughty: )
How about 100 lumens + output + throw = HDS EDC 60 + 40% more. Who am I?
270winchester said:did you miss my recommendation of L5, L6 and L7?
EuroBeetle said:The U2 will make the HDS look like a candle,at least mine will.
Blindspot said:Is there a Surefire LED that could be equated to a HDS 60 on steroids - even if it is somewhat larger? I guess what I am asking is, what LED lights obviously and substantially out throw, and produce more light than, the HDS 60 (excluding those with multiple LEDs - I know my ELX-6 can do it)
I LOVE my HDS 60. I would like to get a single LED torch that SUBSTANTIALLY outperforms it, if such a thing exists - larger form factor not a problem.
Thanks!
CM said:In a two cell (E2e) package, the KL1 with optics will probably out throw the HDS60. A KL1 can be modified to really out perform the HDS60 if you modify the circuit and boost the current to the LED to 700mA. The increase in output is 25% and while small (less than 1dB), it is noticeable and measurable. Some people opt for driving the lux at 1A which is around 50% increase. This should result in around 50% increase in output which is about a 1.8dB in increase which you can definitely perceive. Going higher will get you past the point of diminishing returns.
Blindspot said:Nope - those were the ones I came up with as well by just reviewing claimed lumen output and so forth. I haven't seen a review of the L6 or L7, but the output and throw stats on the L5 are not substantially greater than the EDC-60.
