So, I built this:
to replace the bulb/holder assembly in a TurtleLight. That's a 1W low-dome white Luxeon emitter, thermal epoxied to a 3/8" aluminum pedistal, which is thermal epoxied to a low profile TO-3 power heatsink. (with some plastic spacer things to make it fit in the reflector housing).
Anyways, because of the low-dome beam profile, the spot focused by the TL's reflector is slightly larger, and only a little brighter than the original single white Nichia LED.
Not only that, but the source of light for the center spot appears to be light from the edge of the Luxeon's beam - meaning the pea-green stuff
yuck!
Any suggestions? Should I just bag this and turn it into a candle-type thing? Is the low-dome emitter pretty hopeless for reflector applications? I've tried positioning the emitter in all different depths in the reflector.
-Darin
-Darin
