Nubo
- Joined
- Dec 23, 2004
- Messages
- 461
I'm beginning to wonder if it's just bad luck, or is this light just hard on LEDs? I sent it back twice because of dead and/or flickering LEDs. The first time the 2 sick LEDs were replaced. The 2nd time, they replaced the entire light. Now I've got another LED that flickers on the higher settings.
I don't think I've done anything outside the normal operation of the light. I've never used the overdrive for more than 10 or 15 seconds (recommended 1 minute max). Environmental conditions are normal, and no hard drops.
This is too bad because I really like the concept. And the light served perfectly while I was recovering from a recent surgery -- kept it on low all night as a night-light and used it to navigate the house to avoid falls. It served several days like this and still has plenty of battery power left.
I'm not sure what to do about this; I'm tired of the RMA process. Thinking about soldering in a replacement LED on my own. On the other hand, the socketed "CPF Edition" sounds reasonable, and I could swap out LEDs until I get "lucky" with a robust set of 4. I'm just wondering though if it's just maybe a problem with the way the light drives the LEDs. Seems like I usually start having problems once I've played around with the "strobe" function. I wonder maybe near the top end of "strobe" function the LEDs are somehow overdriven?
Anyway, just looking for others' experience with this light in terms of longevity. LEDs are supposed to last longer than incans, right?
