dilettante
I've been mulling this over since before I found CPF. Here's my current "Ultimate LED Headlamp". It's simple enough that I might be able to build one.
The guts of my "ultimate LED headlamp" would be an aluminum heatsink/chassis mounting a 5-watt and 1-watt LS side-by-side with a single 5mm LED in between. It would also mount a 3-position switch and the required voltage regulation circuitry. Ideally, this heatsink/chassis would be hinged to a plate attached to the head harness so you could aim it.
Apparently a common 9-volt battery will drive a 5-watt LS for about 20 minutes (see the 120 lumen pocket light thread). You could comfortably suspend one to four 9-volt batteries from the back of the head harness. Couldn't you use step-down voltage regulation to drive the 1-watt LS and 5mm LED?
This setup would allow the user to choose between the 5-watt LS (for hiking off-trail or trail running), the 1-watt LS (for hiking on trails) or the 5mm LED (for camp chores and map reading).
