waddzz
Hi, this is my first post but I have been lurking in the forum for a while. Trying to get my head around the numbers, found some explanations on the forum but still can't fit it all together. Say if I had a 50 LED torch each LED running at 20 maH, so presumably, that's 1,000 maH. Say the torch was powered by three AA's and I was to use three NiMH 2,500 maH batteries, so a total of 7,500 maH, does this mean I get 7.5 hours of light? More or less, same brightness, diminishing brightness? What if the batteries were 2,500 maH alkalines, so 1.5V rather than 1.2V, any difference or is that factored into the installed resistors? What about regulated or non regulated, what difference does this make? What about all of the inefficiencies within the torch, does that impact the runtime? Any other numbers to consider?
Apologies if these are dumb questions.
Thanks
Thanks
