I can enlighten you.
The SuperSbin (SS) designation in not an official LumiLED binning. It is ARC mania's way of reserving the best Lux I emitters that go into his lights. SuperSbin emitters are carefully chosen.
The emitters come from a premium reel of Lux I emitters. Each emitter is checked for brightness, tint output, mA draw, H-bin Vf and reliability in his white room. Very few emitters pass his SS requirements.
The SS emitters go into his best lights like the Maxlite AA and KI-B. He is very choosy about what goes in his lights. As many of you know he is eccentric about the quality of his lights. ARC mania…:nana:
Some members have experienced the SS emitters. I've had the chance to own a couple of lights with SS emitters. They can be overdriven for more light or under-driven with a bright beam and longer run time.
Simply said, the SS is not an official LumiLEDs bin code but it does mean the emitter is hand-tested to insure premium qualities. The SS emitter is blessed with many desirable characteristics.
Here is a comparison of the SS emitter to a common popular 1AA light. The ARC mania lights are radically different in character. The Maxlite overdrives the SS emitter and the KI-B emitter is driven below specs. Both lights are brighter then the common light. But that is not the whole story. The KI-B is drawing only 24% and Maxlite AA is drawing only 63% of the power the popular light is. The run time is extended on both the KI-B and Maxlite AA lights with no sacrifice to brightness. You might notice that the SS emitter does not change tint when it is over or under driven.
