Originally posted by MicroE:
Evan---Thanks for pointing that out. i had missed your "cram the optics into the head" statement when I read it.
I was looking to go just a wee bit smaller. I was hoping to get a lens that is 8mm or less in diameter and reduce the whole thing to true ArcAAA size in all dimensions.
Two questions:
1.) How did you "cram the optics" into the head? Did you use a lathe to turn down the lens or its black plastic mount?
2.) How tall is the stack of 1/3AAA's? It looks like the height of three is more than the height of one full AAA.
The A23 combined with reduced diameter optics and a tact switch tailswitch should yield an LS that is bright and the size of a Arc AAA that is quite useful.---Marc
<font size="2" face="Verdana, Arial">Marc,
Going down to 8mm may be detrimental to the function of the optic. IIRC, the forward light from the emitter is collimated through refraction (and out the center "nub" of the optic), and the off-axis light collimated through internal reflection of the optic (along the outside edge). By sanding that down, you reduce its effectiveness in both a) making a rough surface that doesn't reflect internally (scatters), and b) modifying the angle of the light that hits the new surface. A) can be solved by fine sanding and polishing of the surface, but B) can't really be - it will modify the beam pattern.
To shape the optics, I used a hand file, and some eyeballing (note that I didn't show a picture of the optic
). I ground about 2-3mm off the diameter, just at the largest point, then screwed the head in over the optic. I had to back off and tighten several times to make sure it's centered.
The stack of 3 1/3AAA's is EXACTLY the same length as 1 AAA. Some mfgrs cross-label between 1/3 and 1/4 - the part you're looking for should be 14mm in height.
The A23 only has a capacity of about 40mAh (i think? maybe 80). The 1/3AAA are labeled at 100, but are probably like 120. They can feed the luxeon 400mA for about 2 minutes (direct drive). I resistored it down with 2.7 Ohms, putting it at about 150mA. This way, it lasts at full brightness for about 20-25 minutes.
So there are downsides to the 1/3AAA - charging is a pain, and so is getting ahold of them.
However, after all that, it is SO worth the work to get a luxeon flashlight that small
. While it was direct drive, it outshone my roommate's 3D maglight (it's not the size of the light....
Good luck!
-Darin
