OK - this isn't directly on point with these forums, but I think it's close enough and definitely in the spirit.
For a big art project I'm working on I'm trying to put together a small scale version of a traditional searchlight - you know, those things used at movie openings to draw attention from miles away.
factors:
Questions:
Thanks!
-Eric
factors:
- Needs to be able to support being continuously on for periods of around 8 hours.
- I can supply 120vAC (up to around 17 amps) or 12vdc (up to 12amps). 12vAC preferred. The generator's actually a 2800 watt inverter based gennie capable of more than the above amperage, but I want to use the excess for other things. Batteries don't really make sense in this case.
- < 5 degree beam spread - less is better.
- I'd like to get the light output equivalent of 500-1000W of xenon
- I can spend around $600
- Needs to be (somewhat) weatherproof
- It will be fixed in place, pointing straight up.
- I'm fine with used items
Questions:
- Anyone have any ideas of lights that meet the above criteria?
- Would it make more sense to look at using a bunch of lower wattage lights positioned closely together and pointed in the same direction instead of one bigger light?
- Anyone know of where I could get appropriate reflectors if I tried to create my own?
- Know of any existing car headlamps that might work?
Thanks!
-Eric
