Re: Custom cmacclel made 1150/550 lumen Hotwire bulb mod sub 2D
beefy6969 said:
Aftermarket reflector?
Glass lens?
Bored host?
Finned head?
I had the same questions about what was in it when I first read this thread. I eventually found the answers in cmaccelel's original sales thread but I had to go through a couple of links to get there.
For my own reference, I figured I would include a link to the original sales thread (
here) and a copy of the specifications and some of the most useful notes from the original thread:
Specs:
-Approximately 1150 Lumens using ROP High output lamp (1150 Lumens before optical loss)
-Approximately 550 Lumens using ROP Low output lamp (550 Lumens before optical loss)
-Custom 6AA to D holder
-UCL Lens
-Custom PR Base lamp holder
-Camless Medium Stripple Reflector (Zero artifacts in beam Surefire Style)
-10amp Rated Tailswitch
-Sub 2D size
Notes:
-Sorry.....it will not work with "D" size cells as the battery holder is smaller than the standard 2d. [vortechs comments: actually, the body will fit 2 D-cells, although it does compress the tailcap spring quite a bit; it works great with a SMJLED PR bulb]
-With the low lamp you should get around 1:15 runtime with 2500Mah Nimh cells.
-People have used 1.5V Lithium AAs with no issues.
*Why use that ROP lamp instead of a WA bi-pin?
-ROP Lamps are easier to obtain.
-There's a High / Low Lamp in each package for under $10.
-No fussing with the Bi-Pin adjusting hassle.
-Brightest lamp found for 7.2v application.
-Comparable Bi-Pin Lamp WA1111 is the same price for 2 of the ROP lamps
and around 200 lumens dimmer.
