spoonrobot - sorry, I misread...I read you say it outputed slightly less than a third of the G2, but you meant output slightly more than 2/3 the G2. Sorry, but the way it was said was a bit confusing for me.
trumpetmarksman - For my casual, normal, weekend pants, I find the Huntlight pocketable. It's shorter than a Minimag, slightly longer (maybe 1/4 inch) than a G2 and similar thickness to a G2. It's comfortable in my hand as my hand fits perfectly in between the head and the raised portion just in front of the tailcap. Clicky is easy to push and it gives audible and tactile feedback. However, it is a reverse clicky, so you won't have momentary capability and you can't flash/morse code unless you first turn the light on then flash it off with a slight push. Amongst currently available 2x 123A lights, I think the Huntlight is the best value. The Nextorch Z3 offers momentary capability, but it's harder to get and costs a bit more. If you want momentary and don't mind not having HA3, the Pentagon L2 black version (TypeII anodizing) is about $65 + sh. Tho, if you're going to spend $65, might as well throw in another $10 for the TypeIII Pent L2. I do like momentary myself (and appreciate it when I use my Vital Stream with VG FB1 body or my SL TL-series lights), but I can live without it, especially for $33 for a great light.
