Here's the SE Pill:
And some comparitive beam shots:
First up is the Brinkmann 2AA. The threads actually run out just before the reflector moves in enough to focuse a real tight beam.
Note that light measurements are made at 1 meter and beam shots are at ten feet. The Luxeon lens projects about a five foot circle of light at ten feet, where the reflector keeps the beam focused to about 12" at ten feet.
Next up is the MiniMag and Pill combination. The MiniMag does a better job of focusing the beam, but alas, the switch mechanism doesn't function. So some more work would be required to alter the reflector to preserve the on/off switch function. I just wacked the reflector off to get these beam shots.
So, it appears a brighter yet narrower beam is possible using the SE Luxeon and AA reflectors. However, some additional work would be involved to correctly focus the Brinkmann and to make the switch work right in the MiniMag.
