Handlobraesing
Banned
- Joined
- Feb 14, 2006
- Messages
- 2,724
I use my lights quite often and I have two favorites. Eveready 4AA headlamp fitted with Mag Xenon and the SL 4AA Luxeon. I use my lights mainly for urban exploration and the setting can contain a mixture of environments similar to outdoors, rescue and industrial.
The SL 4AA Luxeon is already one of the CPF favorites, so I'll talk about the deficiencies first.
Inside buildings, this light is often too bright and easy to blind my partners with. The ideal setup is two brightness settings. Full output and mini-mag like output.
I would prefer if it was a bit shorter, but no big complaint and I say its about the right size.
Now for the good stuff.
I took my 2D Maglite(LED) and SL 4AA Luxeon to my sites. They cost about the same and I much prefer the 4AA Luxeon. The Maglite actually sat in the rear seat cupholder the wholetime.
Lanyard -
it is VERY handy. I think this is something many people take for granted. On the field, you just got to use both hands sometimes or hang it on something nearby.
Weight -
weighing in at ~8 oz, its not too light, not too heavy
oval shape-
It won't roll down and fall off
runtime -
I have yet to encounter a situation while exploring that needs more than 3 hours of runtime at once. If its likely I'll need tens of hours, I'll carry a dimmer, backup light, so this light has the ideal runtime. With my typical usage of 1-2 hours per site, 3 hours on alkaline and 4.5 hours on NiMH gives me an adequate overhead, but not so much that I carry unnecessary amount of battery bulk.
2D Mag LED would probably run for much longer time and less battery change frequency, but I have to carry along the extra weight/size of the batteries.
water resistance -
I don't usually get it wet on the field, but it gets dirty with graphite dust, grease etc. Ability to spray it down with Simple Green and wash down with water is definitely good.
polymer construction-
non sparking if dropped and less likely to damage the surface on which it is dropped on.
Electrically non conductive. If I accidentally contact across two phases with it, it will not create a shock hazard or short the circuit.
Lanyard -
Weight -
oval shape-
runtime -
water resistance -
