The N2 bulb is nice and bright driven by 6 rechargeables at 7.2 V -- prabably just about what the voltage drop on 3 @ CR 123s deliver.
It would be nice to be able to use this turbohead driven by a single R/C battery. The reason I've delayed is that I haven't been able to figure out how to keep the LA snug in the TH without sacrificing a body with a bonded dummy to wire to the battery source.
I've noticed that there is a depression in the back shank of the TH that gets covered with the TH collar that connects the TH to the body. I'm thinking that I could drill a hole the rest of the way through and use it for a self-tapping set screw that will firmly hold the N2 LA in place. Then, if I wire the R/C battery (with a switch) to the springs of a N2 I can clamp the TH to the R/C battery and enjoy a 2 1/2 hour run time on the compact rechargeable package.
When I put the TH back on my 9P body the hole in the shank will be unimportant because it is inside the various O-ring seals of the standard configurations.
The major complication may be connecting the wires to the springs. The springs appear to be steel so they probably can't be soldered. I'd may have to use tiny clamps if I can't persuade someone with a TIG welder or other small spot welding device to weld the leads.
Any reactions or suggestions?
