LED head for Surefire M6
hiluxxulih
Will a KL6 LED conversion head fit a Surefire M6 ? I had an ld surefire catologue that said it would but I,m not sure .
FredericoFreire
Brazil
I think it fits M3 and M4. Up to 12v only.
M6 holds 6 CR123's. That's 18v. I've heard that KL6 isn't made to handle that.
For me, the best configuration is fit the KL6 into M3 (same as L6) and put 3 RCR123's.. about 11,1v
Just my 2 cent.
seattlite
PNW
A custom turbohead LED module from ARC Mania works great in an M6. That is if you want to go custom. Otherwise its the KL6.
Size15's
Kettering, England
The KL6 is a bit wasted on the M6 body in my opinion since the M6 body has so much more to give...
albino
i agree with "ilum the nation"
maybe it works..... no, it really dos work.
but it looks like :sick2: !!
leprechaun414
Connecticut USA
Is it worth it to put a KL6 on my M6? does it produce anything near the brightness of the MN20 bulb? I have thought about buying one of these LED heads but wasnt sure if it is worth it?
:popcorn:
xpitxbullx
Las Vegas
How long do you think it'll run? I'm getting the AWR M6-R 3300mAh battery pack (soon I hope)
Jeff
Illum
Central Florida, USA
:popcorn:
I think investing into a LED is for loger runtime and batteries that wont be driven as hard as incan
nc987
Your runtime will be amazing. I love my L6 and having 6 batteries behind it for runtime vs the 3 I have now would make it that much better.
Tampa, Florida
Please tell me that the L6 head will not work work with (3) RCR123 batteries. I had decided not to purchase it but if it will work with rechargeables, then I might be up @#$%'@ creek without a paddle... I will be forced to buy it:rant:
O.K., my question is: Will the L6 work on the M3 with (3) x RCR123 batteries = 12.6 volts fresh off the charger?
-Goatee
petrev
SW England
Hi
Someone makes an LED Tower Module that drops in instead of the std. LA
Bogus1 has one ! ! !
Cheers Pete
tvodrd
*Flashaholic* ,
Hawthorne, NV
-Goatee
Two posters above say it is ok with the M4 which is a 4-cell (12V) light, so it should be fine with 3 R123s, hot off the charger.
Larry
