Alin10123 said:The L4 and L2 although have the same peak brightness when it comes to lumens #'s. The extra circuitry eats up the runtime that it would have if it was more simple like the L4.
SCblur said:Personally, I prefer the feel of the L2 in my hands to the L4. It is bigger, but it feels more centered and balanced. Just my preference.
Luna said:That isn't the case. The L2's circuit is supposibly more efficient . The runtime difference is due to the fact the L2 is running the LED at a much higher current than the L4.
Also keep in mind the L2 puts out a more intense beam.
Flashlight Reviews show the L2@780lux (older test was better IIRC) and the L4@512lux This due to the much greater current of the L2. As the batter depletes and/or the light gets warm, the output drops fast. Similar results at the http://www.flashlight-fan.com/flame_page/frame_l2.htm site
Up close and indoors the difference doesn't seem so great but it measures so!
In all likelyhood the intended usage was to use the L2 on low as the *normal output* and the high as a turbo boost mode.
Alin10123 said:But since the L2 has a hotspot+flood instead of just mainly flood, or even sometimes a donut, i figured it was just a different focus.
:)> said:When the mania begins to take hold, take 2 CR123's with a full glass of water and call the doctor in the morning.
-Goatee M.D.
aryntha said:The good thing is: My girlfriend picked one up and said, "Huh, what's this? Really well made." She unscrewed the tailcap, (She works for a camera manufacturer): "Oh! CR123's! I can get lots of those from work!"
aryntha said:Are you sure that isn't "take 2 CR123's and call Surefire in the morning and rationalize why you can 'affordize' the U2 - " oh, wait, no.....
:)> said:Aryntha,
You CAN afford the U2. You just need to prioritize. Skip some meals or rob a bank or something like that. It'll be worth it!
-Goatee
