Fitorch
Results 1 to 10 of 10
Thread: Distinguishing Luxeons
    Feb 2006
    Palmdale, CA
    Default Distinguishing Luxeons
    I just got an Orb Raw and can't tell if it is a 1W or a 3W. How can I tell the difference? Are 3W's bigger?
    -Dan
    Flashaholic* schiesz's Avatar
    Feb 2006
    Lees Summit, MO
    Default Re: Distinguishing Luxeons
    I don't know of any way to tell the difference between a Lux I and III. If the drive levels between those two orbs are different, you should be able to tell by measuring the draw, but I don't have an orb and am not sure how it goes togather, so it might be tough to measure.
    schiesz
    Dec 2004
    Oklahoma
    The LuxeonI and LuxeonIII are probably exactly the same animal, just classified (or binned) at differing currents.
    Apr 2002
    Boise, ID
    If it's on a star board, the Lux III will be on a thick, two-part (1/16" PCB on 1/16" aluminium) star board and have wide power leads. The Lux I will be on a 1/16" total thickness star board and will have thin power leads.
    If it's just the bare emitter, there's no way to tell.
    Mar 2006
    Bracknell, England.
    Turn it on. If it lasts 10 mins and get quite hot, it's a 3watt. If it lasts 30 mins and gets a bit warm, it's a 1watt.
    Flashaholic* TinderBox (UK)'s Avatar
    Jan 2006
    England, United Kingdom
    hello
    the luxeon III star is thicker than an luxeon I, also the legs on the luxeon III emitter are thicker than the luxeon I`s legs.
    see the picture.
    The picture is from another CPF post.
    "Build a man a fire, and he'll be warm for a day. Set a man on fire, and he'll be warm for the rest of his life." - Terry Pratchett.
    Feb 2006
    Lees Summit, MO
    So the lux is mounted on a star in the Orb Raw? I didn't think there was room for it in there...
    schiesz
    Jan 2006
    compare the size of the emitter legs with the picture
    Quote Originally Posted by schiesz
    schiesz
    Feb 2006
    Palmdale, CA
    I guess it's a Lux III (thank you for the replies!)
    -Dan
    Apr 2002
    Boise, ID
    That's a lux III that's been removed from the star board.
    That, or the manufacturer of the orb raw is getting Lux IIIs with thick power leads as a special order from Lumileds.
