Tater Rocket
As some of you may know, I am on a quest to make really bright D cell lights. There is a twofold problem with this. 1 I only have a 4D mag and 2 I have little money
So, what some of you all are going to go do right now is take one of Mr. Bulk's 6AA batt holders, stick 6 NiMH AA's in it, and put a p90 hooked up to it. Does it light up? Bright? How does it compare to a p90 stuck in a 9p? Ok, for those of you with money to spare, stick a p91 hooked up to the 6AA's. I imagine if it doesn't blow right away it will blow fairly quickly.
How did I get the idea for these mods? Well, I checked Brocks webpage and saw that a p90 happens to be 7.3something volts UNDER load. The load is about 1.1 amps, fairly light for a NiMH AA, so 6 would put out around 7.2 volts, or about what the thing wants. So, try it. Now.
A p91 is 6.25 volts under a 2.35 amp load. 2.35 amps is getting up there for a 1600 mA NiMH AA, so I imagine there will be a bit of voltage drop. How much I don't know. I am thinking it would PROBABLY drop to around 6.5 volts, plus or minus some. That is why only those with a spare $20 or $25 to spare is going to do this. Hook it up to the NiMH's. Does it light? Is it brighter or as bright as a stock P91 on fresh batts? If it is brighter that means it is overdriving it and it will blow sooner. If it is just as bright or just slightly less, perfect. I doubt I'll be spending the $25 to get a p91 as it is "only" 200 lumens and I would have to buy a 2D mag to use it. I have a 300-500 lumen 4D mag, and sure I would LOVE to have a 200 lumen 2D mag with a 30-40 minute runtime, but it would end up costing me $40 not including batts (I have just enough that I could do it AND have batts in my 4d at the same time, but barely, and I'd have to pull them out of other stuff) and I'd end up likely needing to buy another 6 or 12 NiMHs bringing the total to $52 or so. Still, not bad for a 200 lumen rechargable flashlight with no operating cost
Anyway, someone try it. Now. You know you want to.
Spud
Spud
