fire-stick
With a good heatsink and the best bin LED (U? I think?) What is pretty much the limit for a LuxIII as far as mA's go.
What type of heatsinking were you using at the time or it doesn't matter in this case?evan9162 said:The bond wires will melt and fuse open in the 2.5-3A range - I've experimentally verified this myself
eebowler said:What type of heatsinking were you using at the time or it doesn't matter in this case?
leeleefocus said:I've got an L2P that has a lux III and a different driver in it and if i measure the current from the negative battery terminal to the body i get 1.95A I've checked this on a calibrated multi meter as i work in the electronics industry i have access to all sorts of equipment but don't know alot about electronics(that could be a bit of irony there) The light gets hot very quickly but is really bright.
The reason I asked was because I believe that the failure point of a Lux III LED depends largly on how well heat is removed from the die and not ONLY on how much current you run through it. If you're talking about an emitter only, failure may be at 600mA. A Lux III LED on an 'O'sink or hotlips may fail close to 2A. If evan cooled his LED with dry ice (-70deg C) the LED may fail at a higher current.evan9162 said:I used a peltier to freeze the luxeon down to -20C. The junction temperature at time of failure was about 140C - over the limit, but not exceedingly so.
