Rebus,
I tested the link I posted above from this thread just now at 10:25pm EDST and it worked just fine. Willie's LVR's incorporte a "soft start" feature which should substantially increase bulb life by dimming up the lamp slowly thus reducing filament stress during startup. It's explained in detail on his website. The LVR's are also programmed to dim the lamp ever so slightly at about 1 Hz when the batteries are depleted to a designated level above the programmed output voltage. This serves as a low battery warning, so there is time to prepare before the battery is depleted. Some versions are available which also incorporate a low voltage cutoff to prevent damage to rechargeables. His regulators are also claimed to be 99 to 99.8% efficient.
One big advantage I can see here is that one could select a suitable lamp that offers a good lumens per watt ratio when overdriven, and although this usually greatly shortens lamp life, the soft start feature and precisely controlled lamp voltage allows one to push the lamp a little closer to the edge without detrement. For example, the Carley #1057 is rated for 6V/2A/12W/19CP/2900K/200Hours. If run at 7.2V/2.2A/15.9W you get 36 CP light output (454 lumens), higher color temperature (whiter), and still get 20 hours or better of lamp life. Lumens per watt also jumps to somewhere around 28! I think this is a fantastic regulator, and I hope to get mine soon.
Later - John
