lightlover
Hi jinng, welcome aboard
Another UK member joins CPF !!
As to your question, please look through the Topic headings in "General Flashlight and Headlamp Discussion".
The subject arises quite frequently, and the answers are many.
Basically, a Candlepower measurement is done at a point in the beam, and represents a brightness at that particular part.
Lumen ratings are a measurement of the total, the whole amount of light produced.
Just as an example of the relationship between the two, without any particular accuracy in the numbers chosen -
Let's say a 1,000 Lumen beam could be rated at 100,000 CandlePower, if it is tightly focused.
But if you take that same lamp, so the same amount of light and change it to a wide focus, it would still be 1,000 Lu, but the CP would drop to a figure of perhaps 5,000.
Still the same amount of light, but not nearly the same measurement of light at just one chosen point.
At the other extreme, a laser will project a bright point of light for a good distance. Even an ordinary red laser has a very high CP rating, because it's a bright spot.
But it's Lu rating is very low - you don't have any real illumination, you couldn't light up a room to see very much with it.
If you are lucky enough to get a Green laser, you can project a point of light well over a mile. And if you shine it at the ceiling of a room, it will throw a small amount of light to see by. So here, you have a combination of a massive, enormous CP rating, and a low Lu rating.
I reckon the Green laser I borrowed from His Most Gracious Telephony has about 3+ Lu.
lightlover
lightlover
