3 C cells with a lengh of PVC pipe or cardboard fax tube of the appropriate ID/OD to make 'em fit, and replace the bulb with 12 or more Nichia
NSWP500BSs. Direct Drive or use a SI diode or resistor to ease up on them. Best lights to modify are like the MagLite, or Eveready or Rayovac "Industrial" yellow plastic 2D lights.
The ones that have the battery compartment physically separated from the bulb, are better and far easier to use than the cheap ones that just press the battery + tip against the base of the bulb. (uggghhhhhh).
If you like red, 2D and replace the bulb with a dozen or more red HP traffic signal LEDs. Bright as heck... The HPs can tahe the 3VDC direct drive in stride. Cheap Radyo Shaq LEDs will become smoke-emitters pretty quickly.
Done both, they do the job...
/ed brown
